Home › Forums › Problems and solutions in GDL › Documentation elements, text handling › FIXING A CUSTOM LABEL WIDTH › Reply To: FIXING A CUSTOM LABEL WIDTH
February 24, 2020 at 03:59
#18581
As far as I know, there is no way to retrieve the text length when using [i]Autotext[/i] values. If you go into the code and change it to [i]Requests[/i] you will then be able to do a follow up request for the length which can then be plugged into the textbox size.
Ling.
Win7 | E5620 x 2 | 24GB | K2200
