Home › Forums › Problems and solutions in GDL › Graphical UI and parameters list › Use buttons to select variable from a parameter › Reply To: Use buttons to select variable from a parameter
March 27, 2020 at 18:35
#18656
Thanks for your reply. This doesn’t really do what I need, I need separate buttons that are apart from each other that activate a different option.
Is there a way to create a boolean button that looks the same as a UI_button?
Thanks
