Home › Forums › Problems and solutions in GDL › Doors and windows › Radial opening sides with wallhole › Reply To: Radial opening sides with wallhole
November 4, 2015 at 19:21
#1891
You should try the wall niche instead – that can create pyramidal or wedge shaped cutting bodies – same as the cutform command.
In some situations, you’ll need more than one cutting bodies to have the proper cut on each sides – especially with reveals. Many of the standard shapes are handled by the WallholeCut macro in ARCHICAD library, you can check that too.
