Home › Forums › Problems and solutions in GDL › Informations from the environment › What is the proper replacement for GLOB_CONTEXT=1? › Reply To: What is the proper replacement for GLOB_CONTEXT=1?
November 6, 2015 at 06:34
#1903
Try this way:
EPS = 0.0001
ha = A/s ! if it is needed later in the script - if not, then move in the "if" below
bCurvedWall = abs(WIDO_ORIG_DIST) > EPS ! later it can be used to determine
if bCurvedWall then
hNg = ATN (hA / abs(WIDO_ORIG_DIST))
Later in the script you can easily separate the parts corresponding to curved walls with the bCurvedWall variable. It’s much better separating working methods by their original purpose, than mixing up context with them.
