Home › Forums › Problems and solutions in GDL › Doors and windows › WALL_COMPS_NAME not being recognised from verion 17 onwards › Reply To: WALL_COMPS_NAME not being recognised from verion 17 onwards
December 9, 2015 at 22:49
#2011
Heimo,
You should cut the exact size and form of the wallhole you need. You can check the WallholeCut macro in the library – that simple macro creates all the magic about wallholes for our library.
To be able to create smaller polygons for cutting the wall, you can use the PolyOperations addon, which helps you modifying polygons.
