Home › Forums › Problems and solutions in GDL › Doors and windows › How to insert a new Tab on default ArchiCad windows/Doors › Reply To: How to insert a new Tab on default ArchiCad windows/Doors
December 16, 2015 at 00:38
#2052
Doug Thornton
If you need solution for AC19, let me know, because that is a lot different (and a bit more flexible).
Hi Dominika. I don’t mean to hijack this thread but I’m working with AC19. I’ve read (and seen) that the “All Parameters” option was removed. As far as I can see the only parameters that can be altered and show in the UI are the listing parameters.
I have several custom objects that the user manipulates with custom parameters. Is there a way to show custom, user created parameters or is the custom UI the only option?
Thanks for your time,
Doug
