Home › Forums › Problems and solutions in GDL › Library build system › LP XML Converter Check Library Error Messages › Reply To: LP XML Converter Check Library Error Messages
#2320
Tony,
I can not help based on this report, it is not a “known and corrected” issue from the past. To help I’ll need the complete workflow what you have done, all the commands in the order you started them and the original files – which can be gsm or xml files.
