Home › Forums › Problems and solutions in GDL › Informations from the environment › Zone Stamp Decimal Places › Reply To: Zone Stamp Decimal Places
March 16, 2016 at 10:38
#2343
Hi Derek,
In your script a form of STR function is used, which is the first form in the GDL Guide:
STR (numeric_expression, length, fractions)
The fractions gives the number of characters after the floating point. If you would like the user to control the number of the decimals, then you can create a new parameter, for example “iDecimals” and rewrite the masterscript:
str_area_m2 = AreaM2Text + str(num_area_m2,8,iDecimals) + ' sq m' str_area_ft2 = AreaFt2Text + str(num_area_ft2,8,iDecimals) + ' sq ft' str_area_acre = AcreText + str(num_area_acre,8,iDecimals) + ' acres' str_area_hect = HectText + str(num_area_hect,8,iDecimals) + ' hectares'
To format the values according to the Project Preferences setting, see the How to display values with units set in Project Preferences? post.
Csilla Mai
