Home › Forums › Problems and solutions in GDL › Object design › Defining materials in a macro › Reply To: Defining materials in a macro
April 1, 2016 at 09:05
#2364
Thank you for your good answer!
Would using the master_gdl file work if the materials should be tied to the library’s objects only, being manufacturer specific? I was also wondering how to bring these master_gdl-defined material choices from the material list to a place where the user can more easily perceive them and see that the choice is limited to them. By means of a material parameter which only lists the preferred ones as values?
