Home › Forums › Problems and solutions in GDL › Parameter connections › GDL label for object info › Reply To: GDL label for object info
May 4, 2016 at 17:12
#2442
Let’s clarify two things: in scripts you can define variables only. Parameters can only be created on the parameter list view of the GDL editor, and the available parameter list of any object is fixed, cannot be changed in scripts (except of the newparameter command in backward migration).
Variables can not be reached or read by labels or listing or addons. If you need to “export” anything from your object, you need to add a parameter for it, and set it’s value in the paramscript. From labels you can reach parameters with a request (ASSOCLP_PARVALUE).
