Home › Forums › Problems and solutions in GDL › Graphical UI and parameters list › ID module in object › Reply To: ID module in object
May 13, 2016 at 15:32
#2469
REQUEST ("Full_ID_of_parent", "", id_string)
For annotation elements linked or hotlinked on the floor plan, returns all identifiers (Master ID) of the linked modules and the parent library parts’ identifier set in the tool’s settings dialog box in the id_string variable (otherwise empty string). Causes warning if used in parameter script.
Is this what you’re looking for?
