Home › Forums › Problems and solutions in GDL › Parameter connections › Full_ID_of_parent › Reply To: Full_ID_of_parent
October 18, 2016 at 11:45
#2792
Ok, didn’t thought that this example is meant with “or master scripts run as parameter script”
What is you suggestion to combine the MasterID with the Roomnumber or the Appartment ID?
We have several customer projects which complex Hotlink structures, where we need a solution for this issue.
Graphisoft Berlin GmbH
