Home › Forums › Problems and solutions in GDL › Lists and schedules › Use Properties from Property Manager › Reply To: Use Properties from Property Manager
Thanks for the posts with help. I am basically trying to make a label placed with the object. The label is an identifier for the schedule. For example, a recessed light fixture with the label R1, R2 etcetera. Using a property allows the use of Excel round trip and the consultant can change the fixture identifier as required, and I would hope that could then update the label on the drawing. I was trying to read the value and then pace it with the text command in the 2d Script. I’ll read through your posts closer to use your suggestions. It doesn’t matter, but I don’t understand why Graphisoft had to place this restriction in the code. I’m sure it causes problems someplace.
Many thanks, JP
