Home › Forums › Problems and solutions in GDL › Object design › 2D view for 3D object › Reply To: 2D view for 3D object
December 1, 2016 at 07:27
#2903
Your object is calling another object called “stages 45” in the 3D script.
I would be guessing this is in the embedded library of your original file which is why it works there but is not loaded in any new file which is why you are not seeing any 3D.
You need to export that object from the original embedded library and place it in your loaded library.
