Home › Forums › Problems and solutions in GDL › Object design › Macros and hotspot2 › Reply To: Macros and hotspot2
January 10, 2017 at 16:31
#2937
If you give exact values to a macro (call "macro" parameters B = 0.9
) then the macro will draw with this exact value… You should use call "macro" parameters B = B
instead to be able to follow the changes of B parameter in your macro’s scripts.
