Home › Forums › Problems and solutions in GDL › Object design › Macros and hotspot2 › Reply To: Macros and hotspot2
January 27, 2017 at 10:52
#2952
Thanks Joachim Sühlo
I checked my script as you said, I try to set STX to zero. But that did not help either. As you see will become STX call parameter STX = -0.075 so when the item is also wrong when I want a 1200 element.
Have you or any other one idea on how I solve this problem.
Or whether it is possible to retrieve a GM file in its entirety into the file that I call element
Thanks
Laurits Frydenberg
Technical drawing
