Home › Forums › Problems and solutions in GDL › 3D modelling › Beam/Column universal object › Reply To: Beam/Column universal object
March 27, 2017 at 11:04
#3159
It is possible to create objects like this, but it is quite dangerous: as there are many methods in ARCHICAD which uses the insertion point and the objects A-B-ZZYZX dimensions as a bounding box, these object will fail. For example: marquee and limited sections won’t show these objects normally, if the insertion points and the bounding box calculated from their parameters are out of the current range.
