Home › Forums › Problems and solutions in GDL › Others › DEFINE TEXTURE does not work in AC 20 › Reply To: DEFINE TEXTURE does not work in AC 20
April 19, 2017 at 03:08
#3182
I am not having any problem with your original code (I had to change the texture image and the fill in the material).
Can you post a screen shot of what you are seeing?
Are your sun/shadow settings the same in both versions?
