Home › Forums › Problems and solutions in GDL › 3D modelling › Hidding contours on double curved edges › Reply To: Hidding contours on double curved edges
July 3, 2017 at 08:12
#3334
Hi Barry. Thank you.
I´m a little embarresed, since I´ve been so focused on the non-existing status codes on the F_Prism that I didn´t even see the H_Prism command….
My problem with the tube solution has been, to create a smooth curve on the tube path line, I can only create a segmented “curve” by straight paths…
