Home › Forums › Problems and solutions in GDL › Parameter connections › Unique Parameter button › Reply To: Unique Parameter button
July 19, 2017 at 08:58
#3403
It seems it only blocks the transfer when you transfer to a new object in the object settings (it is the new object that must have the unique parameter exclusion set so as not to accept that parameter).
It has no effect when transferring between existing objects.
I am not sure this was always the case but I may be mistaken as I rarely use it.
