Home › Forums › Problems and solutions in GDL › Documentation elements, text handling › Stop label mirroring on Hotlinked Module › Reply To: Stop label mirroring on Hotlinked Module
July 20, 2017 at 10:57
#3411
Hi Kristian,
Please add some more information about this mirroring problem.
The problem only appears in hotlinked modules? If you mirror a room with the labeled wall within a .pln file, do you get the expected result?
Could you send a picture of the Label, which behavior would you like to follow in case of mirrored hotlink? And could you please send a picture of your label’s current behavior?
Csilla Mai
