Home › Forums › Problems and solutions in GDL › Others › HOTSPOTs and Associative Dimensions › Reply To: HOTSPOTs and Associative Dimensions
August 9, 2017 at 13:45
#3461
The more I think about this, it’s just wrong and we shouldn’t be concerned with it. What should happen is scripted hotspots should be associative even with no ID. And in fact, they already are, if you use the palette editing. Then I would not give that hotspot an ID, because it is in fact more reliable (no ID to change accidentally or increment wrong.)
We still have the problem of dimming to GEHs, which must have IDs. I can’t reconcile hard coded IDs with parametrics, I’ll need to try a real world case.
