Home › Forums › Problems and solutions in GDL › Graphical UI and parameters list › append current value to the list with ui_button › Reply To: append current value to the list with ui_button
August 22, 2017 at 13:38
#3493
Gergerly – that’s fine I didn’t want to have real-time values.
If anybody wondered – I ended up up with attached script (will append first custom field from layout info). Need to make these buttons work nicer but it works.
Previous question: Is there a way in GDL to check if some variable changed its value?
There is GLOB_MODPAR_NAME but returns null after you click UI_Button.
