Home › Forums › Problems and solutions in GDL › 3D modelling › Double use of buffer › Reply To: Double use of buffer
October 3, 2017 at 08:50
#3562
Hi Bruce,
That way the path will stay in the buffer, but if you use it in a loop, next time you won’t be able to put the profile before that.
One solution is to use arrays, and put the values you need before the tube command.
