Reply To: Temporary Migration for a hotlinked object
Home Forums Problems and solutions in GDL Library migration Temporary Migration for a hotlinked object Reply To: Temporary Migration for a hotlinked object
#3951
Hi Denny,
It’s not a single problem, it is adding a new function to the standard library. This should be done with the proper workflow as you mentioned first, there is no other solution, teher is no migration between duplicates…
