Reply To: Possible to use data from external text file as parameters?
Home › Forums › Problems and solutions in GDL › GDL add-ons › Possible to use data from external text file as parameters? › Reply To: Possible to use data from external text file as parameters?
#4002
This is also a nice solution, you need until pos = 1, meaning the string was found at position 1.
STRSUB returns the substring from position 1 to pos.
var = prefix is only true if var is exactly prefix, not longer.
