Home › Forums › General discussions › Any way to use inline fills in SECT_FILL&SECT_ATRS › Reply To: Any way to use inline fills in SECT_FILL&SECT_ATRS
April 23, 2018 at 10:44
#4016
The trick with MASTER_GDL I know very well…I just wanted to make a fill inside one object and use it in it only ;(
not messing around with the attributes in the project….
Seems the fill defined inline works only for 2d script – even if defined in master or 3d script – the negative values of indexes are “invisible” for SECT_FILL and so on….;(
Piotr
