Home › Forums › Problems and solutions in GDL › Parameter connections › Sense the change of object ID › Reply To: Sense the change of object ID
July 22, 2018 at 22:53
#4196
OK I will answer myself.
Looks like it is wired: if GLOB_MODPAR_NAME=GLOB_ID” just worked…
So in the “previous” (first) run there must be temp parameter prepared say: TEMP_IDX where the previous state of ID is stored (can be of course empty for the start)
then:
if (GLOB_ID#TEMP_IDX) then
will mimic the missing parameters change check.
Piotr
