Reply To: Using updated parameters in properties script
Home › Forums › General discussions › Using updated parameters in properties script › Reply To: Using updated parameters in properties script
#4209
You can’t set parameter values in the 3D script.
This can only be done in the parameter and master scripts.
You can change a parameter value in the 3D script, but it will only be available from that point in the 3D script only.
It can not be used in any of the other scripts.
