Home › Forums › Problems and solutions in GDL › GDL add-ons › Write text file to embedded library › Reply To: Write text file to embedded library
November 8, 2018 at 11:09
#4320
I’ve also tried to get the file to write and read from a loaded library that isn’t the embedded but it still seems to try to write/read to the embedded library and throws up an error until I move it and then ctrl+shift+alt+R then it begins to work with both the reading object and the writing object. Here is the writing / reading code that I have in my objects;
Writing
chOUT=OPEN ("TEXT", "filelog.TXT", "MODE=WO, LIBRARY")
OUTPUT chOUT, 1, 1, symb_pos_x
OUTPUT chOUT, 2, 1, symb_pos_y
OUTPUT chOUT, 3, 1, symb_pos_z
close chOUT
Reading
chIN=OPEN ("TEXT", "filelog.TXT", "MODE=RO, LIBRARY")
n = input (chIN,1, 1, zxzx)
n1 = input (chIN,2, 1, zxzxz)
n2 = input (chIN,3, 1, zxzxzx)
close chIN
