Home › Forums › General discussions › Value liste as text instead of numbers? › Reply To: Value liste as text instead of numbers?
Hi all,
a more flexible way is to use the VALUES{2} command.
set parameter “iVal” as integer
master script:
dim aVal[], sVal[], picVal[] ! parameter value, string shown on UI, icon index shown on UI
aVal[1] = 1 : sVal[1] = “Option 1” : picVal[1] = 2
aVal[2] = 2 : sVal[2] = “Option 2” : picVal[2] = 1
param script:
values{2} “iVal” aVal, sVal
ui script:
ui_infield{3} iVal, x, y, w, h,
2, ! pop-up with icons
picture_name,
images_number,
rows_number, cell_x, cell_y,
image_x, image_y,
picVal, sVal, aVal
This way you can easily re-organize the strings in the popup, by re-ordering the aVal, sVal, picVal arrays. You can rename the strings or swap icons by changing just one line in the master script.
