Home › Forums › Problems and solutions in GDL › 3D modelling › DESCTIVATING A CUTPLANE FROM 2D SCRIPT or similar method › Reply To: DESCTIVATING A CUTPLANE FROM 2D SCRIPT or similar method
March 1, 2019 at 09:16
#4560
Parameters and variables set in the 2D script doesn’t get through via project2 to the 3D script.
You can define cutplanes in the 2D script using the PROJECT2{4} command. Unfortunately it has a bug, so it doesn’t show correct cut fills from the 3D model. You can set a cut fill override if you need only one cut fill.
You can also use PROJECT2{3} with PARAMETERS, setting a hidden parameter whether you need the cutplane or not.
