Home › Forums › Problems and solutions in GDL › Object design › Detecting Line Intersection › Reply To: Detecting Line Intersection
March 11, 2019 at 09:31
#4593
Hi James,
The direction vectors are unit vectors along the lines, their length have to be exactly 1 (meter). Compute the length of the vector between the two points on the line, and to set the vector length to 1, multiply its end coordinates by 1/length.
If you use an EPS value that is common in GS libparts, this code has a small bug, the lines are treated parallel (no intersections) when their angle is smaller than 0.81°, which is still quite noticable. Using EPS = 0.00000001 will set the limit to 0.0081°
