Reply To: Opening oversize no longer instantly updating
Home Forums Problems and solutions in GDL Doors and windows Opening oversize no longer instantly updating Reply To: Opening oversize no longer instantly updating
#4596
Thanks Péter,
Drawing the end lines works but you don’t have the same control when the automatic wall hole is used.
Yes I can check ‘AC_WallContours’ and draw the lines or not.
But when I have 2 opening butting up next to each other, one with an opening extension because of a connecting column between the windows, and I need the side lines, there is a problem.
Drawing them manually they are either on or off – on in this case because I need the side lines.
With the automatic hole there is no joining line even when the side lines are on.
Yes, I could script and control each side line separately, but I really don’t want to.
Hoping this fix will find it’s way into an update soon.
Thanks again.
