Home › Forums › Problems and solutions in GDL › Documentation elements, text handling › Issue with label and surface override › Reply To: Issue with label and surface override
March 11, 2019 at 10:12
#4597
Hi Peter
If you look at the upper part of the attachment the name “A001:Brickwork Face” appears but this is the override surface not the surface of the Building Material. The building material surface is correctly reported in the label text.
This same name tends to be reported in in a new wall.
