Reply To: Issue with label and surface override
#4598
Hi Peter
If you look at the upper part of the attachment the name “A001:Brickwork Face” appears but this is the override surface not the surface of the Building Material. The building material surface is correctly reported in the label text.
That is correct.
The greyed out text is what the surface would be if the override was turned on.
When the override is not turned on, it doesn’t show the actual building material surface – which maybe it should?
Is that the problem here?
The label should always be correct.
