Home › Forums › Problems and solutions in GDL › Documentation elements, text handling › Issue with label and surface override › Reply To: Issue with label and surface override
March 12, 2019 at 21:59
#4604
Hi Peter
But this is so wrong. It means that once an override is made that it’s impossible to know which surface is being used.
When the button next to the surface is NOT pressed then the surface name displayed should be the default or NON overwritten surface. It’s just not logical to display the wrong name. I appreciate this is really outside the scope of this forum but appreciate you help in resolving this issue.
Thanks
David
