Home › Forums › Problems and solutions in GDL › Documentation elements, text handling › Issue with label and surface override › Reply To: Issue with label and surface override
March 13, 2019 at 02:59
#4607
Hmmm disagree with you on that point Barry.
When the override button is pressed it should show the override.
When the override button is not pressed it should show the BM surface.
This is logical and shows the surface visible in 3D, anything else is not logical.
