Home › Forums › Problems and solutions in GDL › Informations from the environment › Railing Panel info › Reply To: Railing Panel info
May 9, 2019 at 16:28
#4737
It seems that the RAILINGPANEL_GEOMETRY polygon goes to the top of the segment (assuming the offset is zero). This makes the panel coincide with the top of the top rail. Is there a global or parameter that represents the top rail thickness, so I can lower the panel top automatically?
