Reply To: Request Object Parameters with Label
#4773
Thank you Joachim,
So if I’m trying to retrieve the value of a parameter “bDoor” (boolean value), I would do the following?
bDoor=”” !!! (does the empty expression initialize a variable regardless of what type it is?)
rrr=request(ASSOCLP_PARVALUE”,”bDoor”, index_bDoor, type_bDoor, flags_bDoor, dim1_bDoor, dim2_bDoor, bDoor) !!! (are the index_, type_, flags_, dim1_, and dim2_ necessary here if I know the nature of the variable I’m looking for?)
parameters bDoor=bDoor
Scott O. Graham, AIA, LEED AP+
Principal
Muhlenberg Greene Architects, Ltd.
