Home › Forums › About this site › Ideas about GDL Center › Comprehensive section on globals and requests
- This topic has 13 replies, 8 voices, and was last updated 7 years, 11 months ago by
Balázs Fürtön.
September 17, 2015 at 11:39 #1456
Shaun Coomber
ParticipantHi
I think it would be useful to have a single resource / section on all options that GDL offers in accessing global and system values:
– Global variables
– REQUESTs
– Fixed name optional parameters
– Existing “Master GDL” parametersIt can be painful looking through separate documentation for each of the above, trying to find the relevant commands.
September 17, 2015 at 16:55 #1459
Csilla Mai
MemberHi,
At the moment all these sections are available from the Information from the environment tutorial.
A separate chapter will be created soon in GDL Reference Guide for accessing global and system values.Csilla Mai
September 24, 2015 at 07:07 #1514
Kristian Bursell
ParticipantI second this request and will eagerly await the new chapter in the GDL reference guide.
CADSWIFT
Australia-
September 27, 2015 at 08:51 #1570
KeymasterKristian, Shaun,
Could you please describe a bit more details about what would you like to read in this new chapter? I think everything is written in the reference guide, so we only wanted to change the structure of the “miscellaneous” chapter, but if there is something really missing, then we should reconsider this.
December 8, 2015 at 21:44 #1990
Geoff Briggs
ParticipantPlease add a tip/trick describing the (new) preferred method for offering a font selector within an object’s parameters. Thanks
Geoff Briggs
DeForest Architects
Seattle, USA-
December 9, 2015 at 18:12 #2005
KeymasterGeoff, I’m not sure it needs a complete post, I’ll try to answer it shortly here. From AC19 we use font types value lists from the “Archicad_library_master”. If you open it from the editor, you’ll see how we add value lists to all the loaded library parts. You can do the same, add your own “master” libpart to your package, and create value list for your own libparts. This master libpart should be under the “Library Master” subtype. Maybe later we can describe it with more details, for now, feel free to ask more questions if needed.
December 9, 2015 at 18:28 #2007
Geoff Briggs
ParticipantThanks. Specific to fonts, can my parts use the list from Archicad_library_master? I don’t want to deploy masters if the values are already available. If that is possible, please post code examples.
Cheers,
Geoff Briggs
DeForest Architects
Seattle, USA -
December 9, 2015 at 18:50 #2008
KeymasterYou can use the font names from our master file, but there can be problems:
- you can’t use those objects without the standard ARCHICAD library
- if we change our master file, then there is no guarantee that your object will work with an upcoming version
If you decide to use our file, you don’t need to script anything, just add one of the font parameters from the master file to your object, and it will work.
December 9, 2015 at 19:17 #2009
Geoff Briggs
ParticipantThat makes sense, thanks for the warning.
Related question: I have some customized markers (one detail and one S/E) and use the built-in parameter AC_TextFont_1 to set the marker head text style. Will that continue to work in the future. Thanks.
Geoff Briggs
DeForest Architects
Seattle, USA -
December 9, 2015 at 22:44 #2010
KeymasterGeoff, as I said before, there is no guarantee for the upcoming versions. I can’t promise you anything about that.
December 10, 2015 at 22:06 #2023
Geoff Briggs
ParticipantOK, thanks.
Geoff Briggs
DeForest Architects
Seattle, USA
October 7, 2015 at 14:17 #1649
László Nagy
ParticipantAround 2000 I have created an illustrated list of Global GDL parameters and Zone Fix Parameters for Graphisoft. These are still available on the old ArchiCADWiki site:
https://195.144.20.131/Global%20GDL%20Parameters
https://195.144.20.131/Zone%20Fix%20Parameters
I would love to see something similar (detailed info with illustrations) and updated for the latest versions. When these were first created the latest version was 6.5.
Laszlo Nagy
ARCHICAD-TALK Moderator, Site Admin-
October 9, 2015 at 07:21 #1686
carlos lopez
ParticipantThat would be really productive, a illustration says more than words.
January 29, 2018 at 13:11 #3784
Balázs Fürtön
ParticipantThe links are no longer alive, it seems.
Balazs Furton
Student of architecture @ Budapest University of Technology and Economics
- The forum ‘Ideas about GDL Center’ is closed to new topics and replies.
