Home › Forums › About this site › Ideas about GDL Center › Display and editing features
- This topic has 16 replies, 5 voices, and was last updated 10 years, 2 months ago by
Gergely Fehér.
September 11, 2015 at 17:02 #1395
Zsolt Taskai
ParticipantIs this the description of the topic itself? This box at topic creation should have a title probably…
September 11, 2015 at 17:03 #1396
Zsolt Taskai
ParticipantZsolt Idea 1: line numbers for the code sections so that you can refer to them in later comments.
September 13, 2015 at 13:13 #1401
KeymasterThanks for the ideas!
Line numbering is now available in the post of Tips & Tricks and Learning sections. With double-click the code changes back to raw formatting for copy-paste. 2 buttons on the top right for raw formatting or opening the code in a new window.
GRAPHISOFT SE-
September 14, 2015 at 05:12 #1407
Zsolt Taskai
ParticipantWow, that was quick! And it’s seems to be perfect (doesn’t affect copying the code).
September 11, 2015 at 17:05 #1397
Zsolt Taskai
ParticipantZsolt Idea 2: some more standard markup language for posts/comments. Markdown? Wiki markup? Or how do you create tables?
September 11, 2015 at 17:10 #1398
Zsolt Taskai
ParticipantZsolt Idea 3: It’s crazy annoying that most controls here are in gray. Like edit, reply, even filter drop-downs. Feels like they are disabled for some reason.
Firefox 40.0.3 on Ubuntu.
September 13, 2015 at 13:35 #1402
KeymasterChanged a bit on colors… Is it better?
September 14, 2015 at 05:14 #1408
Zsolt Taskai
ParticipantThe forum controls seems alright to me. But the search page dropdown is still grey.
September 14, 2015 at 05:22 #1409
Zsolt Taskai
ParticipantZsolt Idea 4: I’m really missing links in the tips’n’tricks on words like ““View_Rotangle” request”, SYMB_ROTANGLE, MOD, etc, pointing to the corresponding section of the manual.
September 14, 2015 at 17:46 #1451
KeymasterA “command and function pool” was added to the end of posts (and some lectures), with links. Hope it helps.
Product Manager
GRAPHISOFT SE-
September 14, 2015 at 18:01 #1453
Zsolt Taskai
ParticipantAwesome! That definitely works. I was more thinking of wiki-style interlinking but this footnote format might be more helpful for others. And as the system evolves, you might find a semi-automatic way of generating these links…
September 14, 2015 at 05:46 #1410
Zsolt Taskai
ParticipantJust a little issue in https://gdl.graphisoft.com/tips-and-tricks/how-to-use-parameter-buffer-in-polygon-related-commands/ . HTML tags are disabled in code sections and rightfully so but this document still tries to utilize them.
September 14, 2015 at 17:41 #1450
KeymasterCorrected, thanks for the notice.
Product Manager
GRAPHISOFT SE-
September 14, 2015 at 17:46 #1452
Zsolt Taskai
ParticipantAnd corrected using the line numbers, cool:) Probably you should search for “strong” in all code samples, I think I’ve seen some in other docs, too. Thanks!
September 16, 2015 at 14:41 #1455
Frank Beister
ParticipantWould be nice if the forum would have the same/similar skin like the other forums. like GDC, beta, German, INT
September 18, 2015 at 08:01 #1461
éptár ltd.
ParticipantHi, I would be happy to see a TumbUp or Star sign near to the Answers. It can show how your answer is usable for the others. Later developer can do a filter, where user can search the most appropriate answer.
October 3, 2015 at 18:13 #1616
Keymaster…and now, let’s go, and vote for the best answers! By the way you can rate the post of the Learning and Tips & Tricks sections with five stars… Please try that too.
- The forum ‘Ideas about GDL Center’ is closed to new topics and replies.
