Home › Forums › Problems and solutions in GDL › Others › Variable Mismatch
- This topic has 19 replies, 3 voices, and was last updated 6 years, 3 months ago by
Lingwisyer GC.
June 20, 2019 at 05:19 #4787
ParticipantHi all,
I appear to have a variable mismatch in the following section of code. Code has been clipped to executed sections. Text outputting my check variable cc returns 0.305 which is correct, therefore at this stage of the code, SquareV2 = 0.305. Yet if I set Pitch_off to 50, SquareV returns -35, which if we work backwards gives SquareV2 = 0.010 rather than the expected 0.305.
If SquareV > SquareV2 - Pitch_off * tan(35) then SquareV = SquareV2 - Pitch_off * tan(35) If Pitch_off > (SquareV2 - SquareV) / tan(35) then Pitch_off = (SquareV2 - SquareV) / tan(35) cc = SquareV2Ling.
Win7 | E5620 x 2 | 24GB | K2200 -
June 21, 2019 at 11:16 #4788
KeymasterHi, is this in a parameter script? Are these variables or parameters?
June 24, 2019 at 02:20 #4789
ParticipantThis is from my Master Script. Used to set minimum and maximum limits depending on the values set for other parameters.
cc is a variable, the others are parameters.
Ling.
June 24, 2019 at 07:39 #4790
KeymasterIf you have VALUES or PARAMETERS based on these in the parameter script, it is possible that the param script is run more than once, and the code you wrote will be executed more than once with different parameter values. Your condition B is based on A, but in the next run A is based on the last run of B.
You might need to use GLOB_MODPAR_NAME in the parameter script, based on which parameter the user changed, only one of the limiting conditions has to be applied.
June 24, 2019 at 11:00 #4791
ParticipantSetting SquareV and Pitch_off to only update when they are modified has no affect. They only affect each other.
Disabling the update of these two allows the script to work, but results in it being possible for values to show that are not the ones being used, being outside the min / max.
If I swap parameter “SquareV2” with 0.305 the Master Script works as it is suppose to for that value.I think you might be right about the Parameter Script being run multiple times, or at least run before the 2D and 3D Scripts. Is there a way to force the Parameter Script to only run once after executing the 2D and 3D scripts?
“SquareV2” does not resolve in the Parameter Script due to being calculated using a requested value, yet if I say “PARAMETERS SquareV2 = 0.305” the incorrect values are still used. This seems to imply the the Master Script is run, then the Parameter Script is looped before the 2D and 3D scripts OR it is just getting confused by the input value from the Parameter Script, and the value calculated in the Master Script and returning 0.
Returning 0 is more desirable then returning incorrect values.
Ling.
June 25, 2019 at 02:25 #4792
ParticipantI am a little confused by your script.
‘SquareV2’ should never change as nowhere in your formula are you setting the value for it.To check for the ‘firstrun’ of the parameter script, you can try using this to catch it…
First Occasion in Progress
n = APPLICATION_QUERY (“parameter_script”, “firstoccasion_in_progress”, isFirstRun)
This command returns whether the current run is the first run or a consequence of a previous execution of the parameter script which changed
some parameters. This command has no additional parameters.
The distinction may be important when a part of the parameter script executes a triggered event – e.g. it handles the pushing of a function button.
isFirstRun: The returned value shows whether the current run is the first runBarry.
June 25, 2019 at 02:37 #4793
That is just a clipped section of my script.
ProHeight = abs(_yMax - _yMin) SquareV2 = ProHeight / ( cos(phi) )Due to requests not being resolved in the Parameter Script, this section will return an incorrect value when it is run for this script.
n = APPLICATION_QUERY (“parameter_script”, “firstoccasion_in_progress”, isFirstRun)So I would include that query in my Master Script and get it to not execute if the Parameter Script has been run more than once?
If isFirstRun > 1 then goto MasterEndLing.
June 25, 2019 at 02:52 #4794
ParticipantPhi in the original script was substituted with 35.
Well… that was unexpected. So I added the “isFirstRun” query to the start of my Master Script followed by a “GOTO MasterEnd” and it appears to all be working. My limits are even showing in the Parameter Script, even though SquareV2 is not being resolved.
Ling.
Win7 | E5620 x 2 | 24GB | K2200-
June 25, 2019 at 03:05 #4795
ParticipantWhelp. Forum will not allow me to edit that post. It did not actually fix anything. Had forgotten to change some substituted values back to the parameter Squarev2.
June 25, 2019 at 03:14 #4796
ParticipantThe Parameter Script needs only to run after the other scripts have run or when it is first initiallised.
June 25, 2019 at 06:58 #4797
ParticipantI would say …
IF isFirstRun THEN execute code.... ENDIFAt least this is what has been mentioned in other posts about it.
I think it may be a little confusing and ‘isfirstrun’ only gets a value when it is the first run.
I am not sure if it gets a higher value on multiple parameter script runs.I still don’t understand your code.
ProHeight = abs(_yMax - _yMin) SquareV2 = ProHeight / ( cos(phi) )SquareV2 still has nothing to do with the first bit of code you posted.
June 25, 2019 at 07:28 #4798
ParticipantThis object has the option to use complex profiles. The issue only occurs when a complex profile is used. The original two equations include SquareV2 and if skipped, the 2D and 3D resolve correctly.
Ling.
June 25, 2019 at 08:47 #4799
KeymasterDon’t think about the master script on its own, in fact it is prepended to the actual script that is run. So it doesn’t help with requests that can’t be used in a parameter script.
You can’t control the execution order of the scripts, generally parameter script is run before the 2D/3D.
Something like this:master script -> param script: sets parameters
all variables cleared
master script again with the new parameters -> param script: sets other parameters
master script again with the new parameters -> 2D script
master script again with the same new parameters -> 3D scriptPéter Baksa
July 2, 2019 at 04:12 #4813
ParticipantSo, I included the following in my Interface Script;
n2 = REQUEST ("Profile_default_boundingbox", myProfileIdx, _xMin, _yMin, _xMax, _yMax) ProWidth = abs(_xMax - _xMin) ProHeight = abs(_yMax - _yMin) SquareV2 = ProHeight / ( cos(phi) )but they appear to have no effect. ProWidth returns 50, ProHeight returns 100 and SquareV2 returns 0 no matter the size of the profile set…
July 2, 2019 at 08:29 #4814
KeymasterIs that a parametric profile, or are you selecting different profile for myProfileIdx?
Parametric profiles don’t work with GDL, they always return their default geometry.Péter Baksa
July 2, 2019 at 10:01 #4815
ParticipantShould probably reword “profile set” to “value of myProfileIdx”.
Some of them probably are, but it does not even return the default values.
Ling.
July 2, 2019 at 10:52 #4816
KeymasterThen this should work. How do you check the return values?
July 3, 2019 at 05:47 #4820
ParticipantIn the 2D Script, I have a TEXT2 that outputs the values.
In the Interface Script I have an UI_INFIELD that outputs the same values.Neither of the scripts contain anything that modifies any of the parameters so they should both be reading the same values from the Master Script, yet only the 2D Script is returning the correct values.
Ling.
July 3, 2019 at 07:37 #4821
KeymasterThe 2d script doesn’t know about the variables in the UI script. You have to write the same request in the 2D script too, or move it to the master script (just don’t use the variables in the parameter script, as the request will be unsuccessful from parameter script).
UI_INFIELD can’t show variables. Is ProWidth and ProHeight a parameter? No matter what you assign to it in the scripts, UI_INFIELD will show the stored parameter values. You would need a PARAMETERS command to change them, but you can’t do it, as this request doesn’t work in parameter script.
You can show variables and current value of parameters with UI_OUTFIELD.Péter Baksa
July 9, 2019 at 05:02 #4824
ParticipantThe 2d script doesn’t know about the variables in the UI script.
Everything else is in the Master Script. It is just a ‘text2 a’ and a ‘ui_outfield a’ found in their respective scripts.
That works. I never thought of using an infield for displaying a parameter.
Ling.
