Reply To: Use buttons to select variable from a parameter
Home Forums Problems and solutions in GDL Graphical UI and parameters list Use buttons to select variable from a parameter Reply To: Use buttons to select variable from a parameter
#18657
This is a boolean exampe with 1 button:
UI_INFIELD{3} “b_MVO_endgroesse”, 0, 0, 25 ,25,
6, Tree_MVO_3, 2, 1, 25, 25, 25, 25,
1, “”, 0,
2, “”, 1
But I am not shure if this looks the same as a UI_Button.
The grafic file Tree_MVO_3 is embedded, if you use an external it must be “Tree_MVO_3” or similar.
This file has 2 grafics beside each other, one for the Value zero, the other for the value 1.
MAC OSx 10.12
