Home › Forums › General discussions › MEP Connection won’t connect › Reply To: MEP Connection won’t connect
May 25, 2020 at 12:15
#18819
Hi Vítor,
If I understand well, you would like to create an object with MEP function.You can find a Tips and Tricks post about creating such object: http://gdl.graphisoft.com/tips-and-tricks/how-to-make-a-mep-equipment-object
These kind of objects do call “MEP_m_ConnectionsACL_4” macro, the objects of the MEP Tools (the objects in the MEP Library) call the “MEP_m_ConnectionsMEP_4” macro.
In case you already knew the post above, please attach your .gsm or .lcf file in .zip format so we can investigate the problem.
Best Regards,
Csilla Mai
