Reply To: Graphic Templates for lists
Home Forums Problems and solutions in GDL Lists and schedules Graphic Templates for lists Reply To: Graphic Templates for lists
#2793
Hello,
I am re-posting this issue.
I tried many ways to come across a solution.
According to me this is a very important issue when dealing with information from BIM.
The structure and example of report is like given below.
Headers Comp Name Comp Code Sum :Ref Quantity Ref Unit Rate Rate Unit Amount
Definitions Component name given to a material Component code mentioned in database The sum of quantity of the skin of all walls calculated through property object unit mentioned in property object Quantity mentioned in database Database unit Component quantity
Example Brick masonry 04123456 1.33 cum 100 Rs/Cum 133
The problem lies in getting (sum of “Ref Quantity”) as project documentation expects summary of components and not list of all element-wise components.
Please see PDF showing above format.
Thanks in advance and Regards
Naraindrra
