Reply To: Open object with current parameters
Home › Forums › General discussions › Open object with current parameters › Reply To: Open object with current parameters
#3294
I just had to do the same thing for Parameter transfer from objects set by the client:
For this I wrote an export routine via GDL TEXT addon. The placed objects then can
export their parameters, which I replace in the XML-Version of the object.
Example:
OUTPUT ch1, 1, 0, ‘<String Name=”best_names”>’
OUTPUT ch1, 1, 0, ”, ‘<Description><![CDATA[“Bestückungs-Namen”]] ></Description>’
OUTPUT ch1, 1, 0, ”, ‘<Flags>’
OUTPUT ch1, 1, 0, ”, ”, ‘<ParFlg_Child/>’
OUTPUT ch1, 1, 0, ”, ‘</Flags>’
OUTPUT ch1, 1, 0, ”, ‘<ArrayValues FirstDimension=”14″ SecondDimension=”1″>’
FOR i = 1 TO VARDIM1(best_names)
ergebnis = best_names[i]
OUTPUT ch1, 1, 0, ”, ”, ‘ <AVal Column=”1″ Row=”‘ + STR(i, 1, 0) + ‘”>’ + ergebnis + ‘</AVal>’
NEXT i
OUTPUT ch1, 1, 0, ”, ‘</ArrayValues>’
OUTPUT ch1, 1, 0, ‘</String>’
MAC OSx 10.14
