Reply To: BMat ID parameter
Home › Forums › Problems and solutions in GDL › Parameter connections › BMat ID parameter › Reply To: BMat ID parameter
#3859
n = REQUEST{2} ("Building_Material_info", name_or_index, param_name, value_or_values)
Returns information in the given variable(s) on a parameter of the specified building material. Expression returns 0 and contains dummy return values (emtpy string or 0) if used in parameter script, causing additional warning.
