Reply To: project2{3} and SECT_​​​FILL command works different in AC18-19 and AC20-21
Home Forums Problems and solutions in GDL Object design project2{3} and SECT_​FILL command works different in AC18-19 and AC20-21 Reply To: project2{3} and SECT_​​FILL command works different in AC18-19 and AC20-21
#3964
Are you opening exactly the same file in all versions or are you just placing the object in the template (or any file) for 18 and then the template (or any file) for 20?
If two separate files are the attributes the same in both files?
Seems to me you might have different attributes for the same index numbers.
