Home › Forums › Problems and solutions in GDL › 3D modelling › DESCTIVATING A CUTPLANE FROM 2D SCRIPT or similar method › Reply To: DESCTIVATING A CUTPLANE FROM 2D SCRIPT or similar method
February 27, 2019 at 20:12
#4545
Nader Belal
I will try make myself clear again.
I need to create a cut plan view in plan AND an elevation view on plan at the same time.
My problem is that with a CUTPLANE active in the “3D Script” will generate an elevation view on plan with it’s upper part is cut.
And if I deactivate CUTPLANE in the “3D Script” the section plan view will not show correctly.
I need both right at the same time … How ?
